I have an install of 2.1.0 on a windows 7 machine. I have a Creative USB Sound Blaster as my audio device. When I pull down the input and output lists, most of my devices have “???” at the beginning.
For example, when the line should say “Microphone [USB SOUNDBLASTER]” , instead it shows “??? [USB SOUNDBLASTER]”. Same for other lines. Some lines will have the actual letters in front like “SPDIF [USB SOUNDBLASTER]”.
Assuming this has something to do with language packs maybe in windows. Hopefully someone has seen this before and can recommend because I have uninstalled probably 10 times and have changed every language or locale setting I could find.
Thanks,
Ronnie
