I have a problem that I can’t locate an answer to despite quite a bit of looking. I’m working on editing an audiobook file, which has background music added at certain points to heighten the experience. I’m trying to separate out the background music so I can focus solely on the narrator’s reading. I, unfortunately, do not have a studio version of either the narrator or the background music to work with. Is there a way to separate the two things (narrator and background music) into distinct tracks without access to studio versions?
Everything I’ve found on the subject seems to focus on inversion as the means to achieve my desired result. Unfortunately, most of what I’ve read suggests I need studio recordings of what I’m trying to drop for that process to work. Any advice or suggestions would be most appreciated.
