Pyle PTED01 not detected
I’m trying to use my Pyle PTED01 with Audacity 2.4.2, and it doesn’t show up when I try to find it in the audio devices dropdown. I checked device manager and Windows sound control panel, and it shows up in device manager but not the control panel. When I first connected the drum kit, my PC said that it set it up. I’m stumped, so what should I do to try to fix this? If it won’t connect, is there a way to transfer recorded files from the PTED01 to my PC? Thanks.
The USB port appears to be MIDI and Audacity is not a MIDI application.
If you have a soundcard or audio interface with line-in you can the Pyle’s headphone output to line-in and record the audio with Audacity.
