Punch, Copy, Paste feature
I’m beyond frustrated at this point and turning to forum members for insight.
I’ve scoured the forums for the above topic and, yes, there are several mentions of it but not what I’m having a problem with.
Also watched HOURS of You Tube videos on the above feature to try & figure out what I must be doing wrong.
I have Windows 10 and Audacity 2.4.2. I found the link to download “punch copy” and “punch paste.”
I then went into Nyquist Plug-in Installer and enabled those two plug-ins.
This is where I’m having trouble. Under “Effects” I cannot for the LIFE OF ME find these two plug-ins. HELP! What am I doing wrong?
You have to enable plug-ins in the plug-in manager so they appear in the effects menu.
Remember to click on the “OK” button below the “Enable” button …
I did that step and they still aren’t showing…
Disregard. I’m such a dumb ass. It was farther down on the list & I didn’t see it! Thank yoU!
Trebor: Would you happen to know how I can “clear the clipboard”? I’ve tried the above feature and now I’m getting an error. I’ve searched the forum and the menu and not seeing “clipboard”.
Open the “Punch Copy” effect, select “Clear Clipboard” in the first control, then click the “OK” button.
The instructions for these effects: Punch Copy/Paste
