As I have progressed I have learned that Punch and Roll is my friend. It has become part of the process and I am comfortable with it.
However, there are times when doing so produces a sort of “pop” sound at the start of the pickup. It can be heard in the redone audio, at the point where the new audio recording begins to fix the previous mistake.
What is the term for this? It takes up a good deal of time to hear the proper transition sounds, but also threatens to cut off some of the previous audio.
No matter where I start P&R, in the middle of room tone or just after a piece of narration, I potentially encounter that “pop”.
Any help would be appreciated. References to education are a great help as well.
I’ll look into it. Although that is new to me. Is that a process outside of punch and roll, after the initial recording? What is causing these distortions?
Hello! I’m having this same issue - hearing a sort of pop sound at the site of the punch and roll splice. Were you able to figure this out? Any recommendations would be so appreciated, thank you!
