Project file could not be saved
Hello.
This is my first time asking a question.
I am a Japanese speaker, so I wrote this question in my native language and then ran it through machine translation. I’m sure there are many clumsy expressions, but if you could help me, I would really appreciate it.
Thank you in advance.
I’m using Audacity to produce podcasts.
I can no longer “Save Project As” for my project files.
My OS is Windows 11 Home.
When I try to save, I get the following error message:
“Failed to write to file.
C drive is either not writable or there is no free space on the storage.”
The solutions I’ve tried so far are as follows:
● Change the file name to alphanumeric characters.
● Check the available storage space.
● Create a new folder for Audacity directly under the C drive and save the file there.
● Create a new dedicated folder in Documents and save the file there.
● Save the file to an external HDD.
● Reinstall Audacity.
● Delete all metadata and save again.
● Install the previous version (3, 7, 6) and try saving in the same way.
● Try saving on another computer in the same office.
None of these methods worked for me.
Also, sometimes Audacity itself fails to start.
When this happens, the following error message is displayed:
Internal error at projectwindows.cpp line 75.
Please report this to the Audacity team (ttps://forum.audacityteam.org/).
Could you please tell me how to resolve this?
Addendum
I’ve forgotten when it occurred, but this error also occurred.
Internal error at D:\a\audacity\audacity\libraries\lib-project-file-io\DBConnection.cpp line 473.
Please report this to the Audacity team (ttp://fourum.audacityteam.org/).
はじめまして。
はじめて質問をさせて頂きます。
私は日本語話者なので、この質問を母語で書いた後に自動翻訳にかけています。拙い表現がたくさんあると思いますが、もしよろしければ、力を貸していただければと思っています。
宜しくお願い致します。
ポッドキャストの制作にオーダシティを使用しています。
プロジェクトファイルの「プロジェクトを名前を付けて保存」ができなくなってしまいました。
OSはwindows11 homeです。
保存しようとすると、以下のエラーメッセージが表示されます。
「ファイルへの書き込みに失敗しました
Cに書き込み可能でないか、ストレージに空きがありません」
とあります。
自分なりに試してみた解決策は下記の通りです。
●ファイル名を半角英数字にする
●ストレージの空き容量を確認する
●Cドライブ直下にaudacity用のフォルダを新しく作り、そこにファイルを保存する
●ドキュメント内に新しい専用フォルダをつくり、そこにファイルを保存する
●外付けHDDにファイルを保存する
●audacityを再インストールする
●メタデータを一度すべて削除して保存し直す
●少し前のバージョン(3,7,6)をインストールして、同様の保存を試みる
●同じ事務所内の別のパソコンで保存を試みる
いずれを試してみても保存できませんでした。
また、時折audacityそのものが起動できなくなってしまいます。
その際は下記のエラーメッセージが表示されます。
internal error at projectwindows.cpp line 75.
audacityチーム(ttps://forum.audacityteam.org/)に報告してください
とあります。
解決法を教えて下さいますでしょうか?
追記
どのタイミングで発生したのか忘れてしまったのですが、こちらのエラーも発生していました。
スクリーンショットで貼りつけます。
internal error at D:\a\audacity\audacity\libraries\lib-project-file-io\DBConnection.cpp line 473.
Audacitチーム(ttp://fourum.audacityteam.org/)に報告してください
