Hello! I am very new to audacity and I need the help asap. I have tried multiple times to import a 10 minutes audio clip worth 24,470 kilobytes but it just doesn’t seem to load into the program every time I try nothing shows up. I have tried the actual import button, I have tried dragging the file, nothing shows up. I have tried shorter clips that I wanted to use and those worked fine. Does anyone know a work around or if there is something I am doing worng
Which version of Audacity are you running? What is your operating system? What format is the audio file in?
