problems with api-ms-win-crt-runtime-l1-1-0.dll
Hi! I just installed Audacity 2.4.1 on my Windows 7 Ultimate 64bit. An error appears informing the missing .dll "api-ms-win-crt-runtime-l1-1-0.dll. I downloaded the file, installed it on system. I restarted the computer, started Audacity, but the error persists. I tried also PCRepair, however, did not work. Can you help me?
Windows 7 is no longer officially supported by Audacity (or by Microsoft).
Your computer’s version of “Visual C++ Redistributable” is probably too old. To update it, download and run the installer from Microsoft:
https://support.microsoft.com/en-us/help/2977003/the-latest-supported-visual-c-downloads
The file that you need to download and install is: x86: vc_redist.x86.exe
