Greetings. I’m having problems connecting my turntable to my new 24-inch iMac which operates Mac OS Monterey version 12.2. The new Mac only accepts USB-c types of peripherals. So I bought an adaptor-hub and tried connecting my Behringer UFO202 USB Audio interface from my turntable and making it work with the Audacity included software (version 3.1.3) and I cannot get any audio signal appearing in my Audacity control panel. Any help would be much appreciated.
Hi. I’m not a Mac guy, but I have two things to look at.
Check that you have MacOS permissions to use the internal microphone. Usually that permission extends to other recording devices.
In Audacity, try Transport > Rescan Audio Devices after plugging in the USB device.
Thank you so much, jademan! Thanks to your advice, the problem has been solved. Cheers!
Glad I could be of help! ![]()
