Problem with importing audio file
The file shows the normal size of memory on the memory stick but opens showing the incorrect timescale with no sound. The file normally opens with a time of about 45minutes .
What has gone wrong?
See attached
So many things could be wrong, almost all of them unrelated to Audacity.
All signs point to a defective audio file.
If it were me, I would try to convert the audio file to a different format and then try to import that file into Audacity.
What does “normally” mean?
What’s the format? Is this an Audacity AUP3 file, or a regular audio file (WAV, MP3, etc.) If it’s a regular audio file you can check the format and details (including playing time) with MediaInfoOnline.
If it’s a regular audio file, does it play in Windows Media Player?
