Problem with audacity
Hello. I write through a translator, so errors are possible. Sorry :slight_smile: My problem is with the Blue yeti microphone and the audasity program. When recording, there are often crackles and clicks, de clicker does not always help, either a whistle, or a rustle, or something else. In other recording programs, this is not the case, only in Audacity. I changed the settings and everything, but these squeaks and rustle remain. Maybe you know how to fix it? Thanks in advance. Miroslav.
Moderator note: I removed your email address to protect you from spambots
The Yeti’s constant whistle/whine can be fixed with a free Audacity plugin called the “mosquito killer” …
https://forum.audacityteam.org/t/high-pitch-noise-how-to-fix-and-how-to-prevent/62489/6
