Problem when using two full-screen windows simultaneously
Hello everyone,
I forgot to report a bug I have since forever: when I have two different projects running on two different windows (in full screen mode), I can’t control the volume of a track on the second window: when I click the cursor to try to change the volume, audacity switches to the first window! The cursor for the control of left-right pan always works well.
In floating windows the problem disappears.
I currently use 3.7.7 version on Windows 11 running on a I7 12-th generation, but I always have had this same problem, even on a windows 10 machine.
Not very bad problem, only a little annoying.
See you soon,
(I’m available for further details if needed)
