Issue:
When the Audacity window opens on a screen, it is the size of the whole extended desktop.
Steps to reproduce:
- Open Audacity on a multi-monitor Windows PC which has the desktop extended over the monitors.
- Position the Audacity window on Monitor 1, then maximise the window. The window will correctly fill the screen on Monitor 1.
- Select File, New. A new, maximised Audacity window will open on Monitor 2.
- On this new window (Monitor 2), un-maximise the window by pressing Restore Down at the top-right. The Audacity window will spread across the whole desktop, across both monitors.
Hope this helps!
James
