problem installing Vamp plugins
I’m using Ubuntu 12.04 and Audacity 2.0.0 (didn’t compile it myself).
I’m trying to install Vamp plugins, specifically the QM Vamp plugins from http://isophonics.net/QMVampPlugins. I took the three files they told me to and copied them into /usr/local/lib/vamp/, /usr/lib/vamp/, $HOME/vamp/, $HOME/.vamp, and usr/share/audacity/plugins, which is where all my Nyquist plugins are (but apparently this doesn’t work?). I thought this would cover all my bases, but apparently not. Any advice?
Thanks!
See the Manual: http://manual.audacityteam.org/o/man/analyze_menu.html#vamp .
Have you enabled VAMP plug-ins in the Audacity Effects Preferences?
Have you restarted Audacity?
Yep. -_-
