Hello, I am learning Qt development and would like to use AU4, which is currently under development, as a learning project. I found that AU4 cannot change the UI by dragging controls through the visual editing interface (design) in Qt Creator. Therefore, I am wondering if it is feasible to migrate the project code to another project created by Qt Designer (which has a visual interface and can edit the UI interface by dragging controls). If feasible, what should I do?
Audacity 4 is very poorly suited as a learning project as we use tons of custom elements, some of which were brought over from MuseScore studio. I’d recommend trying to build a UI from scratch yourself - after managing all of the dependencies, I got a blinking square going within an hour or so. You’d also have the benefit of being able to follow tutorials doing that.
This topic was automatically closed after 29 days. New replies are no longer allowed.
