Previous recorded audio records with new audio on each new recording
hi there has anyone had the issue of when i record a stem/audio track it records ok but when i move to the next stem/audio track in the same project the first recording is there in the back ground ? i have recently had to replace my mixer and was wondering if anyone thinks its possible its a mixer set up issue rather then a Audacity fix ? thanks in advance for any advice . this is causing me nothing but problems .
When you wrote “when i move to the next stem/audio track in the same project” do you mean you are importing an audio file? If so, it is imported into the same project you were previously editing. But this should be obvious, because the waveforms of the previous track will be visible.
