I use Audacity but will be working on a podcast editing project with someone who uses Adobe Audition.
They will send me files after each stage of editing.
Will I be able to import files to Audacity after they have been saved in Audition first?
Or do they need to be saved as an MP3?
Just wondering if this can work, or will it be messy
If possible avoid using mp3 format files during editing:
they inevitably degrade audio-quality to some degree. The mp3 degradation accumulates,
(like a photocopy of a photocopy, of a photocopy, etc).
If you want the best audio quality, have them send you WAV or FLAC format versions. They will be much bigger than mp3 files, but have the advantage of being essentially perfect copies without any data loss).
I have a question regarding a podcast editing collaboration with someone who uses Adobe Audition. They will be sending me files after each stage of editing, and Iām wondering if Iāll be able to import these files into Audacity for further editing.
Specifically, Iād like to know if I can import files that have been saved in Adobe Audition directly into Audacity, or if they need to be saved as MP3 files in order to be compatible. Iām concerned about the compatibility and potential messiness of the process. Regards
Audacity can open, edit, and export any ānormalā audio files (WAV , FLAC, MP3, etc.). Audition can also open & edit these formats.
With Audacity, some formats require FFmpeg but you should stick to WAV or FLAC.
Lossy formats such as MP3 should only be used as āfinal distributionā unless you are stuck with an MP3 original and you donāt have a choice. In that case you should minimize the number of times itās re-compressed. AAC (aka MP4 or M4A) is also lossy compression but itās immune to accumulated damage.
Audacity project files (AUP3 or the older AUP) ONLY work in Audacity and Audition may have a āsimilarā incompatible-proprietary project or session format. You may not need a project file⦠I rarely make one.
