Possible to change the default 'open' location for the normalize mp3 macro?
No matter what I do I can’t seem to get it to change. Pretty sure the location it’s using is the very first folder I used this on. Any suggestions? I’ll uninstall and remove all files related if necessary, just annoying that I can’t change it. I’d be fine if it just remembered the last location I chose a file from. For reference -
  1. I’m clicking on Tools>Macro Manager
  2. MP3 Conversion is already selected
  3. Click on the Files button at the bottom
  4. The folder it defaults to for me to choose what files I want to convert opens up, i’d like to change this location or at least have it remember/use the last location I used.
Thanks for any help :slight_smile:
Nevermind, found it in the audacity.cfg file.
