I have a large sample disc that is comprised of 99 wavs. Each wav contains about 3 separate drum loops.
Is there a way to split these up in a batch? So far the only way I have found to do this is open each file manually and do a detect silence, then export multiple. Would take forever.
Until Audacity’s batch processing feature called “Chains” supports Export Multiple, I don’t think there is any automated way to do what you want in Audacity.
I would recommend using SoX then write a batch script that runs a command to split at silences on mulitple files. Here is an example command .
Note that we don’t make SoX, it is just a suggestion.
