Possible bug: Export Multiple does not apply common Title metadata to all exported MP3 files
Audacity version: 3.7.8 (64-bit)
Operating System: Windows 10 Pro 64-bit
Hello everyone,
I believe I have found a bug when using Export Multiple to export MP3 files.
Before exporting, I enter common metadata in the Metadata Tags Editor.
Example:
  • Artist: RADIO EL SHADDAI
  • Track Name (Title): ADORACIÓN
  • Genre: GOSPEL
  • Comments: COLABORADOR TODOPORJESUS
After the export:
  • The Artist metadata is correctly written to every exported file.
  • The Track Number is also assigned correctly.
  • However, the Title metadata is only preserved in the first exported file.
  • Every subsequent MP3 has its Title replaced by the filename instead of the value entered in the Metadata Tags Editor.
I have attached two screenshots:
  1. Metadata Tags Editor before exporting.
  2. Windows File Explorer showing the exported files and their metadata.
Could someone please verify whether this is a known issue or reproduce it with Audacity 3.7.8?
Thank you.
Seeing the same thing.
