Pop sounds using Soundflower and Spotify
I am using a MacBook Air, Catalina 10.15.7, with Audacity 2.4.2. I am trying to record from Spotify through Soundflower into Audacity, and am having a significant amount of static, or pop sounds, in the recordings I’ve tried… very crunchy. Is the issue with Soundflower, or with Spotify? I have already uninstalled and reinstalled Soundflower but this did not do anything.
I am quite new to all of this. I am wondering if I might need to uninstall/reinstall anything else, maybe Audacity? Any help or advice is most appreciated.
I think SoundFlower is no longer being developed. I’d expect it not to function fully with Catalina. Which version are you using?
Using Audio Hijack, from Rogue Amoeba should be a supported replacement, but it’s not free.
Yes. I tried recording Spotify
What do you want to tell us?
What does it help someone to solve a problem older than 4 years?
Depending on what macOS version is used, Soundflower or Blackhole are the applications you should use. But if you have a problem with these, please open a new discussion and dont hijack a very old one.
