Plugins not showing in Effects menu
I have an Avox Choir plugin (vst3) which is shown as enabled in the plug-in manager but is not showing up in the Effects, Generate,Analyze or Tools menus. I am using Audacity 3.4.2 on Windows 11. Can anyone help? Thanks.
Solved it. I did a rescan and the Avox plugin then worked.
