hello
NOW forget all my precedant e mail i found what a was looking for !
but now i’m stuck with this / the picture will show best
thanks for your time .
[attachment=1]
hello
[attachment=1]
Which version of macOS and Audacity are you using?
I suspect the problem is that you’re using a 64-bit version of macOS, but as far as I’m aware there are only 32-bit versions of the LADSPA plug-ins available. Recent versions of macOS do not support 32-bit apps (or 32-bit plug-ins).
