Hi,
Which plug-in should I download to output MP3 files on audacity 2.3.0 software?
Thanks for your helps!
Hi,
If you use the current version of Audacity you don’t need to install any plug-ins for MP3 as MP3 export is built in.
Is there a reason why you need to use an obsolete version of Audacity?
