Hey there, I’m kinda new here, and I don’t know any coding so…
I haven’t found a plug-in that makes sound 8-bit like, so I’m requesting one here, in hope that someone can make one, please.
Thanks in advance.
Thanks in advance.
Use the “Nyquist Prompt” effect (Effect menu) and paste this code into the text box:
(quantize s 127)
When the number of “steps” is 127, then a signal that ranges from -1 to +1 will be quantized to 255 levels (127 less than zero, 127 greater than zero, and zero itself), which is equivalent to 8 bit audio.
Is it the “Nyquist Command Line”?
(Using Audicity 2.0.5)
“Effect menu > Nyquist Prompt” http://manual.audacityteam.org/o/man/nyquist_prompt.html
Ah, so it is (sorry, I’m not English so Audacity isn’t either ).
Updating this answer 10 years later since people are still visiting this page.
In modern versions of Audacity the Nyquist command is:
(quantize *track* 127)
What this command does is to reduce the precision of sample values to 127 levels, which is equivalent to 8-bit audio.
Note that it does not may normal audio sound like a vintage video game. For a vintage video game sound you could use “Chiptune” software.
Here’s one I found recently that has decent results: GitHub - LemonATsu/pop-to-8bit: A tool for converting pop song into 8bit chiptune song.
