Plot spectrum null test in Audacity
I import a wav track into audacity and then again. So they both should be bit perfect. I invert one and then i select some region of both tracks and then click plot spectrum. Instead of seeing nothing i am getting a bump at about 22khz. Nothing else anywhere else.
Can someone explain why this is?
Surely if i import the same track twice, they would be equal and if i invert one then the sum should not contain anything?
Dither noise ? … Dither - Audacity Manual
thankyou. Yes switching dither off fixes the problem.
