Hi, when I listen to my recorded audio in Audacity, it is very low and hard to hear. But when I export the audio to my PC, I can hear and listen on my PC, I can hear it clearly and normally.
I feel like some setting is off someplace in Audacity playback as far as volume.
Where can I check or adjust? Has anyone had this issue? Thanks
By the way, I record and use a Yeti Microphone, and that is the same method I listen to the audio in both Audacity, and on the PC (It sounds normal listening to it on PC while the volume listening in Audacity very low)
Thanks that helped some, but I had to slide it all the way to the right to have any improvement at all. I am guessing normal playback and sound should be achieved someplace in the middle? Not all the way to the right?
I always have Audacity playback volume at maximum, (But my computer speaker volume is only at 25%).
In some versions of Audacity the recording level slider, and the playback level slider are are swapped over: they are in the opposite meter, (a bug).
So it may be worth experimenting with the slider in the recording level meter, even though you have a playback volume issue.
