Which is…?
So the issue is that you see the green playback meters bouncing in Audacity, but can’t hear anything, and Audacity is the only application that has this problem?
Left-click the speaker icon by the system clock, then click Mixer. Play a song in Audacity. Go back to the Windows Volume Mixer and ensure the Audacity slider is turned up and unmuted.
If that does not help, try rebooting the computer.
Default recording device number: 1
Default playback device number: 3
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.090000
Low Playback Latency: 0.090000
High Recording Latency: 0.180000
High Playback Latency: 0.180000
Supported Rates:
Device ID: 1
Device name: Microphone (Realtek High Defini
Host name: MME
Supported Rates:
Device ID: 2
Device name: Microsoft Sound Mapper - Output
Host name: MME
Recording channels: 0
Playback channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 3
Device name: Speakers (Realtek High Definiti
Host name: MME
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Device ID: 4
Device name: Primary Sound Capture Driver
Host name: Windows DirectSound
Low Recording Latency: 0.120000
Low Playback Latency: 0.000000
High Recording Latency: 0.240000
High Playback Latency: 0.000000
Supported Rates:
Device ID: 5
Device name: Microphone (Realtek High Definition Audio)
Supported Rates:
Device ID: 6
Device name: Primary Sound Driver
Low Recording Latency: 0.000000
Low Playback Latency: 0.120000
High Recording Latency: 0.000000
High Playback Latency: 0.240000
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 7
Device name: Speakers (Realtek High Definition Audio)
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 8
Host name: Windows WASAPI
Low Playback Latency: 0.003000
High Playback Latency: 0.010159
Supported Rates:
44100
Device ID: 9
Device name: Speakers (Realtek High Definition Audio) (loopback)
Low Recording Latency: 0.003000
High Recording Latency: 0.010159
Supported Rates:
Device ID: 10
Supported Rates:
Selected recording device: 0 - Microsoft Sound Mapper - Input
Selected playback device: 2 - Microsoft Sound Mapper - Output
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
352800
384000
Available mixers:
Available recording sources:
0 - Master
Available playback volumes:
0 - PCM
Recording volume is native
Playback volume is native
Solved at last!!. The audacity volume was turned right down to 0 in the mixer.
The only mystery is how it happened as I didn’t know you could access the volume control that way.
For the record the other software was NCH Wavepad. (and it still works but I will now stop using it).
Many thanks to you all for your prompt replies and patience.
It could have happened when you appeared to have selected a host other than MME in Audacity and received an error (-9996 in your first Audio Device Info).
Unless you want to record computer playback with WASAPI host, it may be best to stay with MME host.
If you have more problems, please start a new topic.
