Pesky Pluggin that i can't remove
Hi Everyone I have this error that is really really getting to me now. I have spend half a day trying to fix this. I had this on a previous version of Audacity and now i have upgraded to a new version I’m still getting this error
I have tried to find this pluggin in my:
~Library/audio/Plug-Ins
/Library/audio/Plug-Ins
There is no file that matches. The next step was to remove all the .cfg files, again this didn’t work. I then noticed that the problem pluggin is located in the pluginregistry.cfg as this:
[pluginregistry/Stub/base64:TW9kdWxlX19UaGUgQXVkYWNpdHkgVGVhbV9BdWRpbyBVbml0IEVmZmVjdHNfX01hZ0ovYXVmeC8gICAgL01hZ251cyBAIFNtYXJ0ZWxlY3Ryb25peDogQW1iaWVuY2U=]
Path=MagJ/aufx/ /Magnus @ Smartelectronix: Ambience
Symbol=
Name=
Version=
Vendor=
Description=
ProviderID=Module__The Audacity Team_Audio Unit Effects_
Enabled=0
Valid=0
The problem is when i remove this and save and restart Audacity keeps adding this back in!
The base64 is ended to the following:
Module__The Audacity Team_Audio Unit Effects__MagJ/aufx/ /Magnus @ Smartelectronix: Ambience%
Any help would be greatly appreciated i’m all out of ideas.
Hi
If anyone is having an issue like this, please restart your Mac, this fixed the problem. Even though the files were removed and deleted (emptied from bin), they must have still be picked up for some reason. A restart fixed this issue.
