Sorry, I have an acoustic-electric guitar, and a mic. Both of them are plugged into a small audio interface which is connected to my PC via USB.
Although I intend to record acoustic guitar, the noise happens even when I am not playing. Even when nothing is plugged into the audio interface. I think something might be wrong with my Audacity, or my audio interface, but I cant figure out what. I was using the exact same settings yesterday and it worked perfectly.
I am using a PC that I built, no sound card. Windows 7, Audacity 2.0.5
Audio Interface = Tascam iUR2
I have been trying to upload an attachment of the noise I am getting, but this website keeps refreshing the page once its done uploading.
Please let me know if I should post any more information, Thanks
It seems the Tascam iUR2 has RCA line out. Have you got a line-in on your PC? If so, you should try a RCA line-out/line-in connection between the Tascam iUR2 and your PC. This might work better than any USB connection.
I’m having the same issue and using an iUR2 to the latest version of Audacity on a win7 laptop. See my post. I have a soundclip. Is it the same sound?
The USB connection was suggested also. I don’t have a line in on my laptop. I’m thinking I could get a line out to 1/8 converter to plug into the laptop mic?
Thanks so much, I tried this and it worked perfectly. Zero noise at all . Just curious but, are USB connections generally a bad idea? I saw both options but thought USB would be better
Thanks for all the fast responses! I did not expect to be able to solve the problem within the same day!
You could try using a Behringer UCA-202 as Kozikowski often suggested on this forum (see Re: someone please help me???). This will give you a line level connection into your PC or laptop. It seems to be the best solution when native line-in connection is not available.
From my own experience, and from what I have read everywhere, including on this very forum, you’ll never have any problem with RCA line level connections. Trouble often begins with USB connections…
As I understand it, that will only help if the iUR2 itself (which connects via USB) is the source of the problem. It would be a good diagnostic though if you could connect another USB audio device.
…and usually nothing else. It’s mono, super sensitive, parts of it non-adjustable and easily overloaded.
Soundcard Stereo Line-In (frequently blue) is suitable for connections to mixers, iPod headphone-out, cassette player line-out and other powerful, stereo, high-level signals. It’s usual shortcoming is audio noise from close proximity to the super-noisy video card inside the computer and low quality electronics leading to higher than desired distortion.
USB Soundcards are a good compromise, but can have one serious noise problem. While the audio going to the computer is digital and relatively robust, the power to run the USB soundcard is analog five volts from the computer and can be “dirty” with bad regulation, poor stability or other computer shortcoming. This is the problem for which we recommend a wall-powered USB hub which the USB soundcard uses by itself.
It’s possible to buy a USB soundcard like the Startech ICUSBAUDIO by accident which has no Stereo Line-In, either. It merely duplicates the sensitive Mic-In on your Windows PC. (I use one on a computer with no Mic-In).
The power either comes down the USB cable from the computer, or it comes from the wall, the wall having priority. With everything connected, we can unplug the wall power and watch the lights on the hub flicker as it changes sources. None of the audio connections carry power.
We use a different feature of wall power. It allows us to double USB distance. One ‘unit of USB’ between the computer and the hub and another ‘unit of USB’ between the hub and the device. We do that in the conference rooms where the throw to the table USB conferencing microphones is too long for one cable, but perfect for two.
I don’t know what happens to the lights if the computer is not connected and I don’t know what happens with more than one hub.
