Peak Levels seem limited
Hello
Audacity shows my peaks as -6.02db no matter how much I crank the gain on my interface. Yet the interface LED meter shows that it is clipping. How do I fix this please?
Setup
AKG C214 (4" away from mouth)
DBX 286S
SSL2
I have tried different TRS to TRS cables, TRS to XLR and no matter how much output gain from the DBX I apply or Gain on the SSL2 interface the audio playback clips yet Audacity shows the Peaks as -6.02db and the SSL meter lights up RED which indicates over 0db (clipping)
Gain Set up correctly
https://imgur.com/qDvvlTl
Cranked up gain
https://imgur.com/B6giyaZ
ok I fixed it thanks to help of OBS Discord. They pointed me to this thread:
https://forum.audacityteam.org/t/peaks-limited-between-0-5-and-0-5/42312/1
https://manual.audacityteam.org/man/faq_recording_how_to_s.html#rinstereo
I changed recording channel to Stereo and I can see the clipping using the View>Show Clipping ON/OFF and I can also use the ACX check which now reads 0db Fail as expected.
I have no idea why I had to change from Mono to Stereo, but as long as it works.
Thank you
Your situation is a little unusual. You have a mono interface which is usually OK in mono…
…When you use a stereo interface but record in mono the signals are cut in half (-6dB) so when both channels are combined they don’t exceed 0dB. If you are using both inputs mixed to mono everything is OK. But a lot of people use a stereo interface with only one mic or one guitar, etc. That’s a mono source but when you record in mono (with the stereo interface) the signal gets cut in half.
When you get clipping, it’s the analog-to-digital converter in the interface that clips. So, you can always trust the meters or clipping indicators built-into the interface. (Then you might have to adjust the levels or convert stereo-to mono, etc., after recording.) As you may know, a true-mono file plays through both speakers.
Hi
A further update to this.
I use OBS to record and livestream and use ASIO drivers. Today it was suggested to use another ASIO driver and now I can record to mono to Audacity without having to change recording channel to Stereo.
Hopefully this helps others with the same issue who use OBS and ASIO as I inadvertedly found that recording videos and importing them to Audacity to post had the same -6db peak limit. As well as streaming the volume was lower than expected.
This is the ASIO driver I used for OBS. https://github.com/Andersama/obs-asio/releases/tag/v3.1.1
You select Mono format in the ASIO microphone properties.
