Hello,
I have two tracks and want to make selections from each and then copy them end to end.
So I’ve marked a section of track one, copied it, File>New, now I’d like to paste the selection into a new track.
In an image editing program I’d do “paste as new image”.
Is there no “paste as new track” in Audacity? So how do I do this?
Thank you.
Oh, and Windows 10 x64 and Audacity, both the latest version.
Audacity 3.0.2
Could create a new empty track within your existing Audacity project, and paste there …
https ://manual.audacityteam.org/man/tracks_menu_add_new.html
or open a new (empty) Audacity window, and paste there …
https ://manual.audacityteam.org/man/file_menu.html
Thank you.
Perhaps a great feature suggestion for Audacity 4. ![]()
Rather than doing that, you can:
- Select the audio that you want to copy to a new track.
- “Ctrl + D” (or “Edit menu > Duplicate”)
For the second track, just copy and paste in the normal way.
You can also paste into a new track this way:
- “Ctrl + C” (or “Edit menu > Copy”)
- Click on an empty grey space below the bottom track.
- “Ctrl + V” (or “Edit menu > Paste”)
Those hacks are the bee’s knees! Thank you!
