Bonjour
Je n’arrive pas à faire fonctionner AUDACITY sous windows11 pour enregistrer une musique lue sur le PC.
Quels sont les logiciels nécessaires …REALTEK ?..ou autres …je ne trouve rien dans Windows 11 qui traite de …MIXAGE…?
sur Google je ne retrouve pas les mêmes procedures dans …MON… windows11.
Merci de votre aide.
Hi,
I have the same problem. The choice of the audiosource RealTek, even available in the menu, does not give acces to recording while the microphone option does.
It seems that the issue is likely related to the compatibility of your computer sound hardware with Audacity source through Realtek . Mine, a ACER laptop, does not work properly.
I tried to upload and install the Realtek version recommended (either by Acer or by Realtek. It desinstalled the original one, install the fresh one and Audacity worked for a while, but past the next Windows 11 updating all the sound of the computer is crashed. Only issue: Microsoft on-line repair!
Audacity must solve the problem.
A fan of the application.
Michel.K
If it is not working in windows then uninstall drivers for your sound card, delete them from computer.
Switch off computer and then reboot then goto device manager and see what is installed for Audio and that there are no yellow ?? or RED XX on the icons. If it cannot find the Realtek ones it should at least install the Generic Microsoft ones then you can right click and update driver.
Then goto audacity and set audio device
