Overwrite recording
Is it possible to change a setting in options to enable audacity to record from the cursor position within a track. Effectively overwriting anything in front of the cursor. The default is to always record at the end of the current recording within a track.
Thanks in Advance.
sark
You can do that with “Punch and Roll”: https://manual.audacityteam.org/man/punch_and_roll_record.html
Alternatively, if you don’t want the “pre-roll” behaviour, you can just:
  1. Click on the track where you want the recording to start
  2. “Shift + K” (select to end of the track)
  3. “Del” (delete the selection)
  4. “R”, or click the Record button.
Thanks for that. I come from using an old version od Audition that just records from any cursor point I knew something similar should be possible with Audacity, just didn’t know what to look for. Punch & Roll looks perfect.
Thanks Again
Sark
