Already answered. You posted the Audio Device Info which I asked for, which lets us see all your audio devices. The audacity.cfg file has much less information of relevance.
I understand you deleted audacity.cfg which would make all your settings default, and the problem continued. We know what the defaults are.
Already answered. It just needs renaming to “audacity.txt” (without quotes) then attached as you attached the Audio Device Info.
rtomasov wrote:
I still prefer OS X 10.6.8 and would not give it up until I’m forced to buy a new Mac.
Gale Andrews wrote:Audacity will sooner or later drop support for OS X 10.6 because it impedes developing Audacity for current macOS. It will happen as soon as we fix enough bugs to make a good “final version” for Snow Leopard.
Hello Gale,
It’s been a long time since my latest post and many things have happened.
1-The Sennheiser USB headphones I’ve sent for repair were sent back to me in a new package; no reason was given but, they must have been malfunctioning.
They sounded fine when I first tried them, sound volume was OK.
Then they stopped sounding well; the sound volume is about 50% or less than the sound volume one gets from the internal speakers using a plugged-in standard headphone.
The only difference from what I’ve written on my first post is, I don’t need to select the output device in Audacity in order to listen through a different device selected in System Prefs.
2-I’ve taken the big step and upgraded to macOS X 10.11.6 El Capitan.
The upgrading has had no effect on the output sound volume when listening through the Sennheiser headphones.
I have twice repeated the procedure you or Cyrano have suggested deleting the .plist in /Library/Preferences/Audio but to no effect.
I’ve written to Sennheiser about a week ago telling them about the persisting problem with their headphones but have not gotten any reply yet.
Can only hope to get more help from you if at all possible.
Sorry but I cannot fix your headphones or make them compatible with Mac. The Apple forums might have some further ideas of things you can try. They may suggest resetting the SMC.
Sorry but I cannot fix your headphones or make them compatible with Mac. The Apple forums might have some further ideas of things you can try. They may suggest resetting the SMC. Gale
I’ve posted the issue on the Apple forums but never got a reply.
As to resetting the SMC, this function doesn’t address the issue.
Thanks
Have you tried zapping the pram? Hold down option-command-p-r right after the startup sound to do so…
Zapped the pram. No change whatsoever.
I’m sending the headphones back for repair.
Want them to tell me whether these headphones are compatible with macOS, something I’m beginning to doubt.
They should be, as they use OSX’s built in USB audio class driver AFAIK.
But I’m beginning to doubt that.
I’ve seen other problems with Sennheiser’s USB headphones. And I know the USB audio class driver works well on OSX as there are numerous devices out there that use it. I have a number of those myself and they never fail. Not even if I unplug while playing or recording sound.
Apple didn’t drop support for USB 1.1 audio class. It’s a bug in some Intel chips in some Macs and I believe it has been fixed by a system update. I’m not sure as I don’t have one of the affected machines around.
Apple did drop support for Firewire audio class. But that only affects Apogee interfaces. And one other, the Griffin Firewave. Maybe that’s where the confusion is coming from?
Besides, I think the Sennheiser USB headphones are USB 2 audio class compliant. They need that to be somewhat compatible with USB3 ports…
I think this probably explains it https://discussions.apple.com/thread/7253403?start=0&tstart=0. The takeaway seems to be that Apple Firewire support continues after a fashion for most Firewire interfaces that continue to update drivers for the new Mac operating systems and which can work with a Thunderbolt to Firewire adaptor.
Because Apogee is/was the only manufacturer using FW audio class. The only other device using it, disappeared from the market many years ago. That one, the Griffin Firewave was more consumer oriented and didn’t sell well because it was expensive, compared to USB interfaces.
Apogee, OTOH, is professional high-end gear. And it is, or was, Mac only.
Even some of Apple’s own cables aren’t compatible with the newest Macbooks. One manufacturer had to scrap its entire range of docks. You can’t tell what’s in a USB-C port. It could contain display port, TB2 or TB3. But it might not. Some cables work in one direction, but not in the other. You can even blow up your Macbook, or your phone with the wrong cable…
It’s a jungle, slowly turning into a disaster. I’ve never seen this kind of problems with any technology introduction from Apple, ever. And it’s certainly not better on the Windows side.
Cyrano, Gale, Steve et alia (if any)
I don’t see why this thread is here,
Please, don’t explain why; I’m already at the end of my tether with my issue unresolved and probably unresolvable issue and prefer not to get crazy because of sidetracking.
Thank you
