Hi Team,
Right Now I have Installed Latest 3.5.0 also I have installed the required plugin Exe for Open Vino which is compatible with 3.5.0, but I am not able to transcribe it, throwing error as above.
Thanks
Thanks
Log File
17:55:48: Audacity 3.5.0
17:55:48: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
17:55:48: FFmpeg libraries loaded successfully from: C:\Program Files\FFmpeg For Audacity\avformat-59.dll
17:56:14: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
17:56:14: FFmpeg libraries loaded successfully from: C:\Program Files\FFmpeg For Audacity\avformat-59.dll
17:56:41: Using internal LAME
17:56:57: Using internal LAME
17:57:46: Operation ‘Pre-processing’ took 0.000000 seconds. Poll was called 0 times and took 0.000000 seconds. Yield was called 0 times and took 0.000000 seconds.
17:57:46: Error: In Whisper Transcription Effect, exception: invalid map<K, T> key
17:57:52: Operation ‘OpenVINO Whisper Transcription’ took 0.308000 seconds. Poll was called 20 times and took 0.000005 seconds. Yield was called 0 times and took 0.000000 seconds.
17:58:09: Operation ‘Pre-processing’ took 0.000000 seconds. Poll was called 0 times and took 0.000000 seconds. Yield was called 0 times and took 0.000000 seconds.
17:58:09: Operation ‘Label Sounds’ took 0.101000 seconds. Poll was called 482 times and took 0.000018 seconds. Yield was called 0 times and took 0.000000 seconds.
17:58:43: Operation ‘Pre-processing’ took 0.000000 seconds. Poll was called 0 times and took 0.000000 seconds. Yield was called 0 times and took 0.000000 seconds.
17:58:43: Error: In Whisper Transcription Effect, exception: invalid map<K, T> key
18:03:25: Operation ‘OpenVINO Whisper Transcription’ took 0.282000 seconds. Poll was called 20 times and took 0.000015 seconds. Yield was called 0 times and took 0.000000 seconds.
Hi @Tushar,
Does your username in Windows perhaps have special characters? We just discovered this issue with latest plugins, when using whisper transcription and still looking into it.
Thanks,
Ryan
I got the same problem - windows 10
no unusual characters in my username
No user name is normall only no special characters, however i have installed 3/5/1 version let me see if that works or not also I have installed latest plugin of openvino no now with latest update also this not working on Windows 10 that Whisper or OpenVino is not appearing in Audacity, basically with transcription i want to create SRT with timestamp Thats it
Update after installing Audacity 3.5.1 and latest plugin of Vino it worked fine
