OpenVINO Super Resolution Times Out
I am running Audacity 3.7.5 on an M2 MacBook Air. I downloaded the latest version of the OpenVINO AI plugins and have not been able to get super resolution to work. I tested it on a ~1min piece of audio. I set the steps from the default of 50 down to 10. I used the 5.12 sec “Chunk Size” rather than 10.24 (though have trued 10.24 as well), and set the “Guidance Scale” to 2.0 rather than the 3.5 default.
I have tried other combos as well and so far have consistently experienced the process taking an infinite amount of time to process. I have seen videos on Youtube where the tool only takes a few seconds to process a similar sized chunk.
Is anyone else having this issue on Mac? Have you been able to get OpenVINO Super Resolution to work?
Thanks!
I’m also having this issue. I’m not on a Mac though. I’m on a Lenovo Yoga. I tried waiting it out but it’s been over 6 hours. My patience has its limits. If you find a fix I’d love to know what it is.
