OpenVINO Module not loading
Hi there
I am using Window 11, Audacity 3.7.1 and just installed OpenVINO plugins revision R4.2
After having activated in the preferences and relaunched the program I have the following error message :
“Unable to load mod-openvino module
Error : %1 is not a Win32 valid application”
Could not find an answer on this forum
Thanks for your help
Phil
Hello, @Philpf - could you try to download the latest 3.7.2 version that is available.
I have tried to reproduce this issue with no luck. Could you also share if you are using the 64-bit version of the application?
Thanks. However I could not find any 3.7.2 version, even here
I have checkd and I was not using the 64bit version. So I have installed and it seem to work fine
Thanks
