OpenVINO Error what i have to do?
OpenVINO Error , what i have to do ??
16:21:00: Audacity 3.7.5
16:21:00: Error: Failed to load shared library ‘avformat-61.dll’ (error 126: The specified module could not be found.)
16:21:00: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
16:21:00: FFmpeg libraries loaded successfully from: C:\Program Files\FFmpeg For Audacity\avformat-59.dll
16:21:04: Error: Failed to load shared library ‘avformat-61.dll’ (error 126: The specified module could not be found.)
16:21:04: Error: Failed to load shared library ‘avformat-60.dll’ (error 126: The specified module could not be found.)
16:21:04: FFmpeg libraries loaded successfully from: C:\Program Files\FFmpeg For Audacity\avformat-59.dll
16:31:45: File name is C:\Users\tomds\OneDrive\Desktop\Drums_instrumental.mp3
16:31:45: Mime type is *
16:31:45: Opening with libmpg123
16:31:45: Open(C:\Users\tomds\OneDrive\Desktop\Drums_instrumental.mp3) succeeded
16:31:46: Operation ‘Importing MP3 files’ took 1.515000 seconds. Poll was called 11566 times and took 0.220804 seconds. Yield was called 19 times and took 0.014553 seconds.
16:31:47: Operation ‘Music Information Retrieval’ took 0.000000 seconds. Poll was called 0 times and took 0.000000 seconds. Yield was called 0 times and took 0.000000 seconds.
16:32:00: Operation ‘Pre-processing’ took 0.000000 seconds. Poll was called 0 times and took 0.000000 seconds. Yield was called 0 times and took 0.000000 seconds.
16:32:33: Error: In Super Resolution, exception: Exception from src\inference\src\cpp\core.cpp:107:
Exception from src\inference\src\dev\plugin.cpp:53:
Exception from src\plugins\intel_cpu\src\node.cpp:1535:
Unsupported operation of type: GroupNormalization name: __module.diffusion_model.input_blocks.4.0.in_layers.0/aten::group_norm/GroupNormalization
Details:
Exception from src\plugins\intel_cpu\src\nodes\reference.cpp:17:
Not Implemented:
Cannot fallback on ngraph reference implementation (Ngraph::Node::evaluate() is not implemented)
16:32:35: Operation ‘OpenVINO Super Resolution’ took 32.901000 seconds. Poll was called 50 times and took 4.628523 seconds. Yield was called 48 times and took 1.761810 seconds.
Thanks Tom
The OpenVINO plugin isn’t yet compatible with Audacity 3.7.5. From the download page: Warning: The OpenVINO plugins are not yet compatible with the latest Audacity version . If you want to use the plugin, I’d recommend rolling back your version of Audacity - to 3.7.4.
Thanks :+1: Got back to 3.7.4 it’s partly working, the only one who don’t work is the Super Resolution. Get again a error message. And also it look’s like it would take forever. But not really needed for myself.
Glad it worked. This is a continuing issue. Unfortunately, every time Audacity is updated, there is a waiting period before the OpenVino plugin that works with the new release of Audacity becomes available. So if you are a user of OpenVino, don’t do Audacity updates right away.
Hi everyone,
I have been using Music Separation with OpenVINO for some time now.
This also works with Audacity 3.7.5 and the latest OpenVINO release v3.7.1-R4.2.
Best regards
Christian
Thanks for chiming in @doubleO7 – The existing OpenVINO release (v3.7.1-R4.2) should be compatible with Audacity 3.7.5. If you find that it isn’t the case, please submit an issue here: GitHub · Where software is built
