Open/Import .mogg in 3.6?
Hey.
I upgraded to the new version and i’m having an issue with .mogg files. When I open or import them, only the first stem is visible instead of it being however many were packed in the .mogg. I looked through the setting to see if there was any kind of multitrack import unchecked but I’m not seeing anything. Have we lost the ability to import .mogg and it show all the tracks within?
Thanks in advance
Yes, I’m having the same problem with 3.6.1 in Win10. This build definitely appears to have broken .mogg compatibility. It worked fine for over 18 years.
I have the same issue with 3.6.1 in macOS 14.6.1
This is fixed in 3.6.2.
