Open folder after macro is ended
Greetings, I would like Audacity to open the folder where it saves the file i.e. macro-output after the macro is ended. What command to use in the mp3 conversion macro?
Note: I am converting mp4 files to mp3 using the macro. Then I open the folder it saves it to i.e. macro-output, to use MP3Gain to normalise the file to 98dB. I could not find how to do get Audacity to maintain 98dB.±0.5. So basicalyy I am asking for 2 requests. Much obliged. Thanks
It’s been 11 days. Any help or advice will be much appreciated. Thanks
