Only blue bar? What can i do?
Hy,
since the update i only see a blue bar and it just buzzes. I work with a Focusride interface. But even with a normal USB Micro it just buzzes.
Do you know what could be causing this?
I’ve already tried everything possible.
No. A bad USB port or cable ?
Previous versions of Audacity are available here: Old Audacity versions download
24-bit recording is broken at the moment and will be fixed later today in 3.4.1
