Only 2 channels will record
I just got a new 4-channel sound mixer (Tascam US-600) but when I connect it to Audacity only the first 2 channels record - I’m getting no sound from inputs 3 and 4.
Can someone help me activate all 4 channels? I am sure it is a simple solution but I can’t seem to figure it out. Thanks in advance to anyone who can help!
Look in the Device Toolbar. Does the “Input Channels” selector allow you to select 4 channels?
No, I can only select 1 or 2 inputs.
What operating system are you using?
Could you copy and paste the output from the Audacity “Help menu > Audio Device Info…”
I am using Windows Home 7 Premium. I don’t have the computer in front of me right now but will check in with the second part of your question later. And once again, THANK YOU for the help. I appreciate the support and hope I can reciprocate someday.
Some multi-channel sound devices configure the channels into stereo bunches. Audacity will only record one bunch. If the system can be made to recognize all the channels, there is also the possibility you will only be able to record from 1-2 or 3-4, not all four at once. See what you can dig up.
Hi,
I asked this question a few months back (https://forum.audacityteam.org/t/i-get-the-first-osx-post-hehehe/162/1) but not sure if that thread is still monitored so I thought I’d start anew.
I have a Tascam 4-channel sound mixer, but I can only get the first two channels to record in Audacity. When I go to the input dropdown, I’m only allowed to select either 1 or 2 inputs. Is there a way for me to modify/re-program Audacity to get all four channels to be recorded?
Thanks in advance for the help. I love Audacity and don’t want to be forced to use a different system.
Topic merged.
Also see here http://wiki.audacityteam.org/wiki/Multichannel_Recording#Suggested_devices - if it’s like other Tascam devices, you may find multi-channel recording in Audacity will only work on Windows XP, unless you can persuade the XP drivers to work under Windows 7.
Yes you will almost certainly be able to record four channels simultaneously with ASIO support enabled, but this requires compiling Audacity - see http://wiki.audacityteam.org/wiki/ASIO_Audio_Interface .
Here’s the requested info:
Device ID: 1
Device name: Line In (TASCAM US-600)
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.200000
Low Output Latency: 0.200000
High Input Latency: 0.400000
High Output Latency: 0.400000
Supported Rates:
Device ID: 2
Device name: Microsoft Sound Mapper - Output
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
192000
Not sure you need all that but I pasted everything just to be safe. So, with that info in consideration, is compiling ASIO the best plan of attack? Again, thank you for the help.
Are you sure that is all of it? You should have other inputs such as your built-in sound card inputs, and a listing for the actual playback device that Sound Mapper - Output is mapping to.
Do you have the correct drivers from here http://tascam.com/product/us-600/downloads/ ? You need the 32-bit drivers if you have 32-bit Windows 7 and 64-bit drivers if you have 64-bit Windows 7.
I’m an idiot, didn’t scroll down enough. Here is the full string:
Default capture device number: 1
Default playback device number: 3
Device ID: 0
Device name: Microsoft Sound Mapper - Input
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 1
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 2
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 3
Device name: Speakers (Conexant SmartAudio H
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 4
Device name: Speakers (TASCAM US-600)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 5
Device name: Primary Sound Capture Driver
Host name: MME
Input channels: 2
Output channels: 0
Low Input Latency: 0.000000
Low Output Latency: 0.000000
High Input Latency: 0.000000
High Output Latency: 0.000000
Supported Rates:
Device ID: 6
Host name: MME
Input channels: 2
Output channels: 0
Supported Rates:
Device ID: 7
Device name: Primary Sound Driver
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 8
Device name: Speakers (Conexant SmartAudio HD)
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Device ID: 9
Host name: MME
Input channels: 0
Output channels: 2
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Selected capture device: 6 - Line In (TASCAM US-600)
Selected playback device: 3 - Speakers (Conexant SmartAudio H
Supported Rates:
    8000
    9600
    11025
    12000
    15000
    16000
    22050
    24000
    32000
    44100
    48000
    88200
    96000
    192000
Available mixers:
Available capture sources:
0 - Master Volume
Available playback volumes:
0 - CD Audio
1 - Master Volume
Capture volume is native
Playback volume is native
I installed the correct driver but am still only able to see two inputs with my Tascam plugged in. Do I need a different recorder/mixer?
Once again, thank you for walking me through this.
Your Tascam is listed twice for input devices - device 1 and device 6. Both have 2 input channels.
Audacity can only access one device at a time for recording, so it looks like 4 channel recording will not be available in Audacity (unless you build Audacity from the source code with ASIO support, but that’s not an easy job unless you have experience with C++ programming).
Programs that support ASIO should be able to record all 4 channels (for example, try Reaper). You can still use Audacity for editing once you have the raw recordings.
