Old audacity and compatable lame
Hello.
I have Audacity 1.3 Beta (Unicode) as I prefer this version or versions that have the layout near enough the same to it.
What lame_enc.dll should I use?
I’ve tried downloading different lame_enc.dll but none seem to be recognised.
Unless there an Audacity that looks close to 1.3 Beta Unicode that has a current working lame_enc.dll - I’d be happy to go with that as an alternative.
Windows laptop.
Thanks.
Good luck with a 22-year-old version
The only thing I can think of, is make sure it’s the 32-bit version of lame.
I don’t know if it used the DLL or the EXE so you might try both.
Or export as WAV and use a 3rd party MP3 encoder.
Please only reply if you have solutions, not snide comments. Thank you.
“You can also find 3.98.2 that is known to work with 1.3.x”.
https://lame.buanzo.org/
