Hi. I need some help about making a Nyquist script for making a siren synth generator for the Siratone siren series. Can someone help me pls? I’d be appreciated ![]()
An updated version of the code from this post: Tone Generators: Siren - #2 by steve
;type generate
(setf duration 10.0) ; duration in seconds
(setf low-hz 700)
(setf hi-hz 1220)
(setf level 0.4)
(setf reverb 0.03) ;amount of reverb, 0 to 1
(setf hz-range (- hi-hz low-hz))
;Make a skewed triangle waveform
(defun env-table ()
(let* ((env-table (pwlv -1 0.55 1 1 -1)))
(list env-table (hz-to-step 1.0) t)))
(setf *mod-table*
(seq (mult -1 (sum -1.002 (pwev 1.002 0.527 0.002)))
(pwlv 1 0.473 0)))
(setf *mod-table* (list *mod-table* (hz-to-step 1.0) t))
(setf *table*
(sum (mult 0.5 (build-harmonic 1 2048))
(mult 0.025 (build-harmonic 2 2048))
(mult 0.025 (build-harmonic 3 2048))
(mult 0.005 (build-harmonic 4 2048))
(mult 0.002 (build-harmonic 5 2048))
(mult 0.0003 (build-harmonic 6 2048))))
(setf *table* (list *table* (hz-to-step 1.0) t))
(setf siren
(let ((mod (osc (hz-to-step 0.21) duration *mod-table*))
(env (sum 1.4 (hp (osc (hz-to-step 0.22) duration (env-table))0.3))))
(setf mod (sum low-hz (mult hz-range mod)))
(mult 0.5 env (fmosc 0 mod *table*))))
(mult level (jcrev siren 2.0 reverb)) ; add a bit of reverb
The only change I made was to change the first parameter in build-harmonic from a float (decimal) to an integer (whole number.
I’ve no idea if it is a realistic “EOWS-612” siren sound as I’ve no idea what that is, but it does sound like a pretty realistic siren to me.
I’ll explain what it is: So, the EOWS-612 Is a tornado siren model from the Siratone series, and it kinda sounds like this:
I wanna create a siren synth of this siren and it needs to be realistic, ya know?
Well as I’ve shown you an approach to generating siren sounds, maybe you can have a go at creating the sound that you want.
