NS1 Noise suppressor - opinions?
Hi folks.
So I’ve been experimenting with NS1 for voice recording.
Any opinions on this plugin?
It’s great at cutting the unwanted background noise but
I seem to notice an increase in Bass by using it.
Any thoughts/tips?
Thanks
Location/Link?
If you’re referring to the “Waves” plug-in, I would recommend using one of the officially supported host applications: Supported Hosts | Support - Waves Audio
