Not working export M4a, gives error
When I load an audio in M4a, some modification and try to re-export it as M4a, the program closes automatically and comes out a crash that when I give it to send is not sent.
Hi,
Which version of Audacity are you using? Can you export the modified file to another format like WAV or FLAC and does it still crash if you do?
Mark B
