I am not very experienced using Audacity, and I realize that this is a very elementary question. I am using Windows 10, and my version of Audacity is 2.1.3. I have a question about normalization. I used Audacity to make a 2 channel recording of a streaming talk show which is about 1 hour and 18 minutes long. The recording level shown by the wave form on the screen, which is centered at “0”, never gets above about +/- 0.4 on the vertical scale. I selected and highlighted the entire waveform using “Edit”, “Select All”. I then selected the “Effect” drop down menu, and selected “Normalize”. “Remove DC Offset” and “Normalize Maximum Amplitude to -1.0 dB” were both checked. I then hit “OK”. The normalization process started. It took about 5 minutes. There were no error messages. The problem is that I expected the waveform on the screen to get bigger vertically when the normalization process was finished. But it did not get any bigger. It remained exactly the same amplitude as it was before normalization was applied. I tried the normalization again, and the same thing happened.
Am I correct to think that the amplitude of the waveform should become larger when normalization is complete? Or am I not correct about this? Could I be thinking wrong about this? How can I know if the normalization worked? Any help would be appreciated.
Thanks,
Carl Lewandowski
