So I’m forced to record some audiobooks in a noisy hotel room with a noisy laptop (fan sound).
After I record the audio, I have to blow up the WAV using the ACX specs here: https://wiki.audacityteam.org/wiki/Audiobook_Mastering
- Effect > Equalization > Select Curve: Low roll-off for speech, Length of Filter: about 5000 > OK.
- Effect > RMS Normalize: Target RMS Level -20dB > OK.
- Effect > Limiter: Soft Limit, 0, 0, -3.5dB, 10, No > OK.
So here’s my question:
If you absolutely must record in a room with lots of background noise (constant hum), then is it better to keep the Audacity microphone “Recording Volume” slider low? Or is this just superflous.
In other words, since i’m in a noisy room, and i need to post-process all this audio anyway, is it better to set that “Recording Volume” slider to a small value (like .10) – working under the theory that, perhaps i “won’t pick up as much” of the room noise. (As I would if I were to set the “Recording Volume” to .50 for example).
Ideas?
Thanks!
