Noise Reduction Tool in edits
Running 3.7.5 on Mac OS Sequoia 15.6.1
I can no longer select a noisy bit of the timeline and just use the noise reduction tool to quieten it.
Any ideas what the workaround is for this? I used to just select the noisy bit, and use my noise reduction tool on it, but now it won’t let me do that.
Help?!
Make sure snapping is turned off.
